Zone Lookup: Custom CSS for Exporting PDF
676
10-02-2025 10:59 AM
MLG-GIS
I would love to find a way to customize the export result on my Zone Lookup Instant App (unfortunately not a public app). Right now when I export, it shows the map and then on the second page it shows the Layer Pop-up Details, followed by the Layer Name.
Can this be reorganized using CSS?
Ideally I would have the results populate in 2 columns to save space, but my main concern is the content preceding the titles.
Thank you!
MLG-GIS
Example of print out:
JessicaJackson
Hi @MLG-GIS
I would also love a way to style the placement of the map and legend and have some more control over the header.
For your case though, the export is pretty much just a screenshot of the results, so you could style your popup into a table.
KellyHutchins
Esri Notable Contributor
@MLG-GIS yes its possible - but it can be tricky. Can you show me what your popup looks like in the ArcGIS Online Map Viewer so I can understand the issue where the content precedes the titles? That part may be a bug.
We do want to add additional support for layouts in the export but we do not have a time frame for when this capability will be available.
KellyHutchins
Here's an example of side by side results. Note this probably needs some cleanup but is an example of styling the output.
@media print {
  .instant-apps-export-print.instant-apps-export-print__pdf {
    display: grid !important;
    grid-template-columns: minmax(0, 2fr) minmax(260px, 1fr) !important;
    gap: 16px !important;
    align-items: start !important;
    height: auto !important;
    min-height: 0 !important;
    max-height: none !important;
    overflow: visible !important;
  .instant-apps-export-print__view-container {
    grid-column: 1 !important;
    grid-row: 1 !important;
  .instant-apps-export-print__legend-container {
    grid-column: 2 !important;
    margin: 0 !important;
  .instant-apps-export-print__content-container {
    grid-column: 1 / -1 !important;
    grid-row: 2 !important;
    display: block !important;
    /* Start results on page after map */
    break-before: page !important;
    page-break-before: always !important;
  #printPopupInfo {
    column-count: 2 !important;
    column-gap: 18px !important;
    column-fill: auto !important;
  /* Keep heading with the next result card */
  #printPopupInfo > h2 {
    margin: 0 0 6px 0 !important;
    break-after: avoid-column !important;
    page-break-after: avoid !important;
    -webkit-column-break-after: avoid !important;
  #printPopupInfo > h2 + .popup-content {
    break-before: avoid-column !important;
    page-break-before: avoid !important;
    -webkit-column-break-before: avoid !important;
  /* Cards */
  #printPopupInfo > .popup-content {
    display: inline-block !important;
    vertical-align: top !important;
    width: 100% !important;
    max-width: 100% !important;
    margin: 0 0 12px 0 !important;
    /* Allow pagination so all results print */
    break-inside: auto !important;
    page-break-inside: auto !important;
    -webkit-column-break-inside: auto !important;
  /* Prevent wide table cells from blowing up the column width */
  #printPopupInfo .esri-widget__table {
    table-layout: fixed !important;
  #printPopupInfo th,
  #printPopupInfo td {
    white-space: normal !important;
    overflow-wrap: anywhere !important;
    word-break: break-word !important;
  #printPopupInfo .esri-feature,
  #printPopupInfo .esri-feature__size-container,
  #printPopupInfo .esri-feature__main-container,
  #printPopupInfo .esri-feature__content-node,
  #printPopupInfo .esri-feature__content-element {
    min-width: 0 !important;
