Zone Lookup App Not Returning Selected Lookup Results
421
04-02-2020 07:08 AM
JeffJensen3
In using the Zone Lookup App and it's not returning results on a layer in my web map which were brought in from the Living Atlas (Public Land Survey System).  I have configured the labels and it works in my web map just not in the app.  Are there certain layers that will not work with this app?
BethRomero
Hi Jeff,
Unfortunately, there is a known issue with map service sublayers in Zone Lookup.  To workaround the issue I suggest adding each layer from the service individually that you would like returned in the results.  I haven't been able to reproduce an issue with labels, could you share specifics or report the issue to support.
