Zone Lookup App Features Returned
1015
10-22-2019 09:01 AM
JeffSchroeder
Trying to use the zone lookup app to return remonumentation points located within a survey section.  Will his app return point features intersected by the selection polygon.  Cannot seem to get any results.
Tags (1)
BethRomero
Hi Jeff,
There is an option within the Zone Lookup app to use a polygon layer as the search geometry.  To enable this option, open the configuration panel of the app, navigate to the Search tab and check on the check box at the very top of that tab, then select your survey section polygon from the drop-down list.  Next move to the Lookup Results tab and check on the point layer you want returned in the results. Hope this helps.
