Sidebar Show Table
1964
06-12-2023 12:19 PM
LondonWalker
I can't seem to get the show table configuration to work. It will turn on, but it won't add anything. Is there a way I can get it to show up?
KellyHutchins
Esri Notable Contributor
The option to open a table should show up on the layer list component. You'll see an icon next to the layer name. Configuring that capability can be a little confusing (we are working on improvements for this) because you have to select the layer you want from the list above and then enable the capabilities (like table) that you want to see for that layer. So in this example we've enabled the table for the Unified School District layer.
Also try launching the preview version of the app and see if the table icon appears there.
Screenshot 2023-06-12 at 2.04.50 PM.pngScreenshot 2023-06-12 at 2.04.50 PM.png
KellyHutchins
LondonWalker
Thank you. This seemed to be my issue. I have a group layer, and it won't add the table for the group layer or show the individual layers in the dropdown, so I have to add the layers individually to get the table view.
WalkerJared
My table view is enabled and the table shows in my Sidebar Instant App, but when I try to Export to CSV the table does not download.
N_W_S_E
Having this same problem, I believe Export to CSV is broken in Sidebar.
KellyHutchins
Are either of the apps public? I just tested with a sidebar app in Chrome and was able to successfully export to csv
