Reporter layer and incident configuration
881
10-04-2024 10:46 AM
ACharvin
On reporter, is it possible to show the issue as the value from a field within the layer? As it is possible on Experience builder lists and such so that Instead of it showing the values like
Layer name :1
Layer name : 2
It can show them like:
Issue name  (Pulled from issue field on the layer)
Thank you!
SubaKrishnan
Hi @ACharvin, you can configure the form to customize what to display on the report header and its details. If you can provide me with a sample app and a use case for this workflow I can look into this. thanks.
