Instant App slider application problem
319
03-11-2026 08:30 PM
AndrewWelsh
In the Slider Instant App, I've been having issues getting the label to display properly at different steps when the increments are in decimals i.e. 275.10, 275.20 etc. Although the slider has steps at each of the increments chosen (in this case 0.10m), the display label only updates at each whole number/integer e.g. 275.00, 276.00 step.
Confirming the data field is double data type, decimal places (2) have been set for the field in the web map and thousands separator turned off.
Can the instant app display the decimal value at each step in the slider label and if so, what other things can I try to get it working?
ClioClark
Hi Andrew,
I have just tried this with some test data, and I get the same result as you - the slider value only shows whole numbers. I would recommend raising a support case with your local distributor so we can look into whether this is expected behaviour or not.
All the best,
Clio
