UI issue when saving a screenshot in the Atlas Instant App
164
11-19-2025 01:28 PM
BrandonGuo
When saving screenshots, if the user hasn't set a map area and clicks the Preview button directly, the toolbar may cover the button. On certain screen ratios, the button can be completely obscured, leaving no way to go back except by refreshing the entire page.
Tags (1)
ClioClark
Hi Brandon,
Thank you for raising this issue. I have encountered the same problem when previewing a screenshot. I would recommend raising a case with your local distributor so we can investigate this issue further.
I found that if I resize the window so that the toolbar at the bottom of the page resizes (see below), the buttons become visible. This looks like it is only an issue when using Atlas on large screen devices.
