Error in AGOL Local Perspective Template
1683
05-08-2017 03:56 AM
BenHolmes2
Hi
We have noticed there is an error in the AGOL Local Perspectives Map Template.
When the distance search unit is set to Meters, it returns the distance in the table on the right in miles (with a meter label)
I downloaded the JS for the template and saw that there is no IF statement in the ProximityInfo.js file relating to Meters (around line 225). So it only returns the default distance (miles).
Can someone look into this, as it would be nice to have the results return in meters
Thanks
Ben
KellyHutchins
Esri Notable Contributor
Ben,
I spoke to the dev for this app and he'll get support for meters added to the next release of Online.
Kelly
KellyGerrow
Esri Alum
Hi Ben,
Can you share a link to your app or a screenshot of what you are seeing?
-Kelly
KellyHutchins
Ben,
Kelly
BenHolmes2
Wonderful! Thanks for that Kelly.
Ben
