edit widget not working in sidebar instant app
1103
06-26-2025 11:58 AM
L77
My edit widget was working yesterday in my sidebar instant app.
After last nights update to AGOL (6/25/25), my edit widget is no longer working.
The select button is missing in the edit widget, and the edit button in the pop-up window is missing too.
SarahMcDonald_Esri
Hi @L77
This has been resolved. The edit button in the pop-up should be there now. Let me know if you are still seeing any issues with that.
Thanks!
Sarah
SarahMcDonald_Esri
Hi @L77
Thanks for reaching out about this. I am looking into this now, in the meantime - if you open the map in Map Viewer and open the edit tools there, does that look as expected?
Thanks!
Sarah
L77
@sarahsara
I can edit in the map viewer.
I noticed the "select" button is gone from the Edit widget. But I can edit using the select by lasso or rectangle. So maybe this is a design change and not a bug?
The edit button in the pop-up window is now missing thought, and that seems like it would be a bug and not a design change?
SarahMcDonald_Esri
@L77
Thanks for getting back. Yes, the select button has been replaced with the multiple selection tools. These are new as of this release. If you use the icon next to the hand icon that will act like the select button used to.
We are looking into the missing edit button on the pop-up now. Will respond back once we have more information.
Thanks!
Sarah
SarahMcDonald_Esri
Hi @L77
Thanks!
Sarah
L77
@SarahMcDonald_Esri The edit button is back and it is working great, thank you!
