display pop-up information in a side panel
11827
05-05-2017 03:07 PM
AllisonHoff
Hello
I am trying to make a story map or configurable web app where the pop up information displays in a side panel. I am sure I saw this option - but don't know where. I am designing an app for a possible internship provider for high school students. The 'client' said he wished he could move the pop up so it would not cover up the feature - so I suggested the side panel. The interns may have to use this in the field so I think a table could take up too much room on the screen. Suggestions, ideas, warnings welcome!
Thanks in advance,
Allison
KellyGerrow
Esri Alum
Side Panel pop ups are also available configurations in these configurable apps. The apps have some different interactions to display the pop ups so see which one will work the best for your use case.
The minimalist (and embed map) have side panel pop ups. They can display when you click on a feature or if you search for a feature in your feature layer: https://webapps.maps.arcgis.com/apps/Minimalist/index.html?appid=3d75398b402b4d73a53d4fb564512d35
The information lookup app enables you to display information from multiple layers in a side panel pop up. Example
The Geo List app also displays pop up information in a side panel as it guides users through specific features. Example
See which app works best for you or look into custom coding using the link Rickey Fite‌ mentioned
Let us know if you have any questions,
-Kelly
RickeyFight
KellyGerrow
Esri Alum
-Kelly
