Customize information lookup template
8975
14
02-10-2015 11:49 AM
KendellRyan
I have been using the Information look up template (hosted). I now have a need to change the geocoder for the app and have it different than the geocoder we default to in our AGOLO site.  I downloaded the files for the lookup template from github.  I have it working locally with my map, However I cannot seem to get it to pick up on my geocoder.  I tried changing the URL in the commonConfig.js and/or in the default.js (the section with helper services).  However there is something else going on beyond there that I am missing.  I'd appreciate any suggestions. I am a novice with javascript but I've gotten some of the other templates customized and working.
NicholasGross
Nothing jumps out at me except that my locator has many more candidate fields. It is a composite locator, not sure if that makes a difference.
MikeMillerGIS
Esri Frequent Contributor
Mine is also a composite.  At this point I would log a bug with Tech Support.  If there is an issue, it would be in the search dijit that this app uses.
NicholasGross
Ok, thanks Michael.
NataliyaLys
I am having the same issue. I downloaded the template, and would like to add my custom geocoder to it. And since I am not js developer, I don't seem to have much luck with it.
It sounds like you guys might have got it to work, I was wondering if you would be willing to help me.
Thank you, Nataliya
LeonardOlyott
Sorrry Nataliya
I am not a developer either and I have struggled a bit with editing the search functions. I basically want the address lookup to be constrained to Australia or within a bounding box. I have copied the code from GitHub and host it on Amazon S3. I then register this app with my AGO account and add it as a template to my template group. I can see it there but it doesn't behave like I think it should. I will let you know what I find out.
Len Olyott
Esri Australia
Industry Solutions
E [email protected]<mailto:[email protected]>
P 61 (0)427 185 181<tel:61%20(0)7%203218%204173>
F 61 (0)7 3211 1310<tel:61%20(0)7%203211%201310>
Level 3, 111 Elizabeth Street Brisbane QLD 4000<x-apple-data-detectors://5/3>
PO Box 15459 Brisbane City East QLD 4002<x-apple-data-detectors://6>
