There is no option of adding Map Legend in Chart Viewer Instant app. Kindly assist.
@alkalim The legend setting is in the full setup of the app in the About section. This can be found by toggling off the Express setting. One way to find any setting in Instant Apps is to use the search. It's located in the top left corner of the configuration panel.
Thank you Beth. This really helped. I appreciate.
