Pop-ups in Web Editor Template (Instant App)
891
7
02-09-2026 12:44 PM
Status: Closed
Bud
Legendary Contributor
I've created an AGOL instant app from a web map using the Web Editor Template.
I want to view the attributes from a hosted feature layer point in a pop-up while creating a feature in a different hosted feature layer.
As far as I can tell, there isn't pop-up/identify/explore functionality in the Web Editor Template instant app. Could that functionality be added?
More info here: AGOL Map Viewer Idea - Keep explore popup open when creating new feature
Tags (1)
7 Comments
EmilyGeo
Hi @Bud
Thanks for sharing your idea. Pop-ups are supported in Web Editor. To view a pop-up:
  • Select a feature
  • Open the Selection pane
  • Click the options menu next to the feature name (...)  and choose Show pop-up.
Hope that helps!
Bud
@EmilyGeo
Thanks! I wonder if this idea is still valid. Could a single-click pop-up button be added to the main UI?
Would it help if I changed the title of this idea to something like "Pop-up button in main Web Editor toolbar"?
EmilyGeo
Hi @Bud
Yep, the idea to access a pop-up with less clicks is totally valid, and something we're considering. It would be great to post the idea on the Web Editor board so folks can give it a thumbs up it there as well, and we can get an idea how important this is to Web Editor users.
Thanks again for sharing your idea!
Bud
@EmilyGeo Feel free to close this idea.
I created a separate Web Editor idea: Pop-up with fewer clicks
Cyprus_Forest_Department
@EmilyGeo the workaround does not work when the pop up comes from an imagery layer such as the World Elevation GMTED. I want the user to click so as to get the elevation from the popup and populate the Z field of a feature layer. Is there a way to support this workflow? Thanks.
IanWittenmyer
Status changed to: Closed
Bud
@IanWittenmyer On a side note, I think you should be merging duplicate ideas instead of closing them. That's how it's done in other Esri idea communities.
