My idea is to increase the size of the Custom CSS text box.
The current text box size makes making any edits within instant apps very hard to do. A larger window would make it easier to make changes to the Custom CSS.
My current process is to copy the current Custom CSS from the instant app to a notepad, make the desired change (hoping I typed everything perfectly), then copy/paste it back into the tiny text area. Repeating the process if I want to tweak the color, or size.
Displaying the entire Custom CSS makes it much easier to read and edit
Thank you
Ryan
Hi @RyanBohan ,
Thanks for reaching out about this. As of the November 2022 ArcGIS Online update this should now be available. The Custom CSS text box size was increased in the configuration. Hopefully this should help improve the editing experience.
Thanks!
Sarah
Thank you, this is a huge improvement and makes the css text box much easier to use.
