Introducing Reporter (Beta)
14963
32
02-29-2024 06:48 AM
SubaKrishnan
5 32 15K
Reporter (beta) is a new Instant Apps template that offers the ability to view and submit reports to a single map with one or more editable feature layers. The app displays a web map, a side panel with a list of layers, and a button to submit a report. The web map renders all the features from the layer(s) for visualization and interaction. The panel displays all the editable feature layer(s) to view existing report, submit new reports, and easily share individual reports or features. This app is set to replace for the existing Crowdsource Reporter app.
Set up the app
In Reporter (beta), you can add single map with at least one editable layer. The app can be created from the Instant Apps home page without any content or with a web map from Map Viewer or from the item details page of a web map. In the app configuration you can add map from the available options in the map stack. The process of adding map to the app is different from Crowdsource Reporter since groups are no longer a requirement for this app.
Once you have completed adding the desired map into your app, you will have options to configure the additional capabilities (not a complete list of options):
  • Reporter options: Select reporting layers (only applies to editable features), configure report button text, configure report submission text.
  • Header: Choose to include or not include a header in the app.
  • Basemap toggle: Ability to switch to a different basemap.
  • Theme settings: Change the appearance of the app by applying dark or light mode, add a logo to the header, and use custom or predefined colors to style certain elements in the app.
  • Map area: Includes the Map view and Navigation boundary options. The Map view option allows user to set a map extent at which the app opens. Then, in the Navigation boundary option, set boundary limits for map extent and scale.
  • Basic map navigation tools include Home, Zoom tools, Bookmarks, Legend, or Search in the map.
View and submit reports
Reporter (beta) displays all the editable feature layers in the side panel. To view a report, the user selects a layer from the list and navigates to the desired feature to view the details. Alternatively, interacting with a feature on the map opens the popup details of the feature on the side panel if the feature is from an editable feature layer.
To submit a new report, the user clicks on the ‘Report an incident’ (configurable text) button either from the main layer list or within a layer to submit a report. The intuitive workflow lets users add or draw the feature’s geometry on the web map and enter the smart form with additional details, along with an option to attach related multimedia. The recently added report appears at the top of the feature list of the layer.
Share functionality
To share, the user clicks on the Share button on the side panel to open the Share dialog with options to share the feature details, and the web map.
Roadmap
Reporter (beta) will have additional updates in future releases. As this is the beta version of the app, it is a paired down version of what the app will eventually offer. Here are the updates that we are still looking into and plan to make available in future releases of the app:
  • Like, Dislike and Commenting option.
  • Filter and Sort options in the feature list.
  • Configurable options to choose the reporting layers.
  • Configurable options to choose the polling layers. This feature is set to replace for the existing Crowdsource Polling app.
  • Improve user experience for the app.
Try it out
We appreciate your feedback to continue improving our templates. Comment below or use the ArcGIS Instant Apps Ideas page. Explore the live sample, or use Reporter (beta) sample app in ArcGIS Online or create your own app.
Please be aware of the breaking changes to Reporter after the upcoming June 26th, 2024, ArcGIS Online release.
32 Comments
HenryUnderwood1
I am excited this is being updated! I noticed that I am no longer able to create a reporter app using the old version. Is that correct/expected?
BethRomero
@HenryUnderwood1 The option to create configurable apps has been removed from the Group item page, but the Crowdsource Reporter configurable app is still available to use from this link: https://www.arcgis.com/home/item.html?id=74b016cef7db42b28599adc5a14b010c
HenryUnderwood1
@BethRomero The link takes me to the new version. Can you update the link?
SubaKrishnan
HenryUnderwood1
My comment so far is that the map zooms in way too far when you click on an existing point on the map. This should be controllable as to whether it happens or to what scale the map can change. It makes users zoom out a lot or hit the home button to go back to browsing existing information.
Town of Temple Complete Street Project (arcgis.com)
Edit: there is a workaround for the zooming issue. In the app, you can set a maximum extent as well as minimum and maximum zoom levels. Change this as desired to prevent "zooming in" too much.
SubaKrishnan
@HenryUnderwood1 Its a known issue and we will be fixing this behavior in the next release. Thank you for sharing your observation.
GordonDixon
Occasional Explorer
Hi
The Insta Reporter (Beta) is awesome. Simple and clean.
Is there a way to make it in English and French? For the most part I can control most of the text in both languages, but it is the small details eg having a Next and Cancel button where I cannot change the text. Also the tips with the little light bulb show up in English
Thanks
SubaKrishnan
@GordonDixon Thank you for your feedback! The beta version only supports English language. We're planning to get it out Beta next release and the app would then support translations.
DannyLawlor
Is there a way to configure the "Choose a category for your report" and "Please provide the details for your report" text that appears after clicking on the "submit report" button? In my case, what I'm using the reporter for does not mesh well with the word "report." Same goes for the "Click on the map to add to add a point" text. I'd like to have the ability to alter or remove these text blocks to improve the user's understanding. I was able to to change the "Report submitted message" text and "Submit report button text" (both in the "Reporter" section of the app configuration).
Also, I know the zoom action has already been identified as an issue that will be addressed, but I'm just seconding that it does cause problems.
Thanks
SubaKrishnan
Hi @DannyLawlor In the upcoming release in 2 weeks, we've changed the strings and will not be using the word 'report'. And, we've fixed the zooming issues too. Please note there will be new features added to the reporter app and it will be out to beta.
DannyLawlor
Hello @SubaKrishnan
Thanks for getting back to me so quickly! I'm glad to hear about the upcoming changes.
I have an additional question.
I see in the Roadmap above that a like, dislike, and commenting option has been planned. Is this option part of the new features that will be added in two weeks?
Thanks again for your help.
SubaKrishnan
@DannyLawlor Yes, it is added as planned. Please feel free to reach out if you have any questions. I'm happy to help!
DavidG
Occasional Explorer
Hi @SubaKrishnan
I really like using the reporter app and I'm happy to hear that an update is coming.
Does this update mean that the reporter app can also be configured in a dashboard? (Now it can only be embedded, but as a result, I miss out on the functionalities and integration of the dashboard.)
Furthermore, is there a possibility to add pop-ups with a hover function or in the middle of the screen like in other webviewers? Currently, the comments and pop-ups are in the same left menu, but users have mentioned that they find it annoying not being able to view reports and feature information simultaneously.
Thanks
SubaKrishnan
@DavidG I'm glad to hear that you enjoy using reporter app.
In the upcoming version of the reporter app, it can still only be embedded in the dashboard. And, we've added an enhancement to show popup on the map for the non-editable layers/reference layers when clicked on the map.
TeamGEOHHSK
Hi @SubaKrishnan
It's great that the Reporter app is getting an update; it is a really nice addition to the available instant apps! I was wondering if the upcoming version will also support displaying the info-box that can be configured in Field Maps Designer. It currently doesn't show up.
I've made a post about this and a related problem before: Required field and calculated expression not working as intended?
Thanks
SubaKrishnan
Hi @TeamGEOHHSK I tried configuring popup with calculated expressions with Field Maps Designer and its working with the reporter app.  The new version of the app will be out next week and if you still have any issues, please feel free to reach out to me or log a support case. Thanks!
DannyLawlor
Hello @SubaKrishnan,
You helped me recently with some questions I had about the beta version of Reporter. I have some questions about the Reporter app now that it is out of beta. I don't see a new thread for the new version. Would I be able to ask those questions here? Should I reach out directly to either you or @BethRomero (authors of the "ArcGIS Instant Apps: Introducing Reporter" article)? Or, Is there another way to go about it?
Thanks for all your help thus far,
Danny Lawlor
SubaKrishnan
@DannyLawlor. You can reach out to us directly. Happy to help!
KimSapunar
I was a regular user of the crowdsource polling app, using the 'comment' feature on attributes.  I have a test map using the new Instant App Reporter.  When I add my geodatabase with an editable layer and a related comment text file, I can't access the fields from the related file in smart form within Map Viewer.   I think I'll need to do this first, so that in the Instant app the relate ID field would be hidden, etc.  Do you have a suggestion? Thanks
SubaKrishnan
@KimSapunar Could you verify if the table shows in the TOC ? When you select a layer >Forms and you  see the second screenshot?
Yes, you've to configure the smart form first before using it in the app.
If you still have issues with map viewer, please contact esri support. Thank you!
Amanda_Larson
I'm having issues with map popups. I'd like the popups to only work for the data which I'm collecting, not the background data.
I've disabled popups in the map I'm using but when I use the map in the Instant Reporter, all popups work. And, typically, it's the background layers (such as parcels and municipal boundaries) that pop up first before the point layer.
Additionally, is it possible to remove the Sort function at the top of the left panel window? Its not obvious that it is a sort button and its unnecessary. The whole panel is almost unnecessary if you have the settings set up so that the users can only Add data and not Edit existing data.
SubaKrishnan
Hi @Amanda_Larson We're aware of the app showing disabled popups and it will be fixed in the upcoming release. Sort option is not removable or configurable. The sort UI is uniform across all the apps in ArcGIS online and it has a tooltip for additional context. Could you explain more about which panel is unnecessary? Are you referring to the report panel, and what do you mean by editing existing data? Report app only lets users to submit a report and interact with it if the options are enabled.
Amanda_Larson
@SubaKrishnan When is the upcoming release? Is there a workaround?
The panel to the left being open but showing nothing important seems unnecessary except for, of course, the button at the bottom of the panel. Maybe the button should be at the top so its easier to find?
And, you're right, you can't edit existing data in the Reporter. I am currently working on 2 identical apps. I'm trying to duplicate the Reporter using Experience Builder and when I'm logged in, I can edit and even Delete point locations even though I have disabled the Delete function. I assume it's because I'm the data creator and admin. I'm trying to figure out which gives a better user experience or user interface. The editor widget in EB has its own issues so I'm not settled on which to use yet.
SubaKrishnan
@Amanda_Larson The upcoming release is in November and there is currently no workaround. The panel doesn't collapse and it's the integral part of the reporter workflow of data collection and soliciting feedback to view the layers and as a user clicks through the layers, it lets them add a new report and view, interact with the reports which is all configurable. We'll consider the report button to be on top. Please share if you have any questions or feedback regarding reporter.
In my opinion, pick an app that serves better for your needs. Both of the products are evolving and we'd happy to take in your feedback.
DavidG
Occasional Explorer
Hello @SubaKrishnan , some time ago you helped me with a question regarding the reporter app, so I hope you can help me again. I have a map in the reporter app with multiple layers. I would like to add filters to some layers. For this, I need to add layers in the "panel options." That is not a problem in itself. However, when I place a comment via the report button, all layers that are checked in the panel options automatically become active, even though I only have one layer active at that moment. Is this a bug, or can I change this in the app? The same happens when I use a filter on one of the layers; after turning off the filter, all layers become visible while they were previously turned of. I'd like to hear from you, thanks!
SubaKrishnan
Hi @DavidG Could you explain what you mean by "when I place a comment via the report button, all layers that are checked in the panel options automatically become active, even though I only have one layer active at that moment" Do you all layers are rendered on the map or panel? "all layers become visible while they were previously turned of" Do you mean layers turned off the panel during config is turned back on after removing filter? Are you using filters in the map viewer or attribute filter in the config?
DavidG
Occasional Explorer
Hi @SubaKrishnan I'm using attribute filters in the config. Is it even possible to use filters in the mapviewer? I could not find that option.
As you can see I have the same layers in the left section (panel) as in the right section (layers) because I need attribute filters on those layers and this is the only way I could find to do that (If you have another way, please let me know).
So, in the first image, all layers are turned off except for the one I want show. However, when I leave a report (second image), all the layers below the one I had on, automatically turn on, which means I have to manually turn them off one by one again."
Ideally, I would like to make the layers visible only in the layer view, but I can't find a way to apply an attribute filter on those layers, except in the config under the reporter section.
SubaKrishnan
Hi, @DavidG Yes, you can set map filter and it's not dynamic as attribute filter. The option is on the left ribbon in the map viewer.
Are you turning off the layers in the map viewer but it turns on as you interact with it in the app? This issue you're noticing is a known issue and it will be fixed in the next release, and when the layers are off in the webmap, it will not be rendered on the map but it you still report on it, if its report collection is enabled on the app config. Hope this helps. Let me know if you've any questions.
LinzMess
@SubaKrishnan @Amanda_Larson
I would also like to see enhancements allowing the reporter app to focus more on reporting and less on viewing submitted reports (or at least make reporting the primary use). Currently, the Reporter panel lists existing reports and users have to look to the bottom of the screen to find the button to submit a report. Being the "reporter" template, it seems like the primary use case should be reporting, not reviewing reports. Perhaps the reports list can be moved below the "Submit a report" button and also have the option to default to either expanded or collapsed? This way the app designer has control of the focus of the app!
Hi @LinzMess Thank you for providing your feedback. The primary use case of reporter is both viewing existing reports and submitting new ones, and we cater to the needs of different use cases for our customers. I understand the difficulty of finding the button and we will review your feedback and come up with suitable solutions.
LinzMess
@SubaKrishnan
I would like to enable the status bar in the report details similar to what is shown in the Introduction Blog post for the reporter app dated June 27, 2024 ArcGIS Instant Apps: Introducing Reporter
Is this still a feature? If so, how do I configure the status bar?
Hi @LinzMess   You can use attribute expressions in Map viewer and edit the layer's popup to make use of these
SubaKrishnan_0-1731977599450.pngSubaKrishnan_1-1731977619041.pngSubaKrishnan_2-1731977657168.png
MarkNewman
I have configured an Instant Reporter App, see Street improvements Reporter ,which is getting a lot of use, however I have had feedback from a number of users that when they go to submit a request, users can click on a location on the map or use the address search box
If the user uses the address search box the application will ask them to log in!
As most users will not have an ArcGIS online account this is not possible!
As I have always been logged into ArcGIS Online when configuring the app, I did not notice until users fed the issue back!
I have gone through all the configuration options and have not found a way of rectifying this issue!
Are you able to help?
BethRomero
@MarkNewman by default the Reporter app adds all locators in your organization and one of the locators must not be accessible to app users not in the org. We are looking at adding in an option to configure the search locators in the form. In the meantime, if you remove the locator from the Organations settings (Org settings < Utilities < Geocoding) that will fix the prompt to sign in. In my test, the locator that seems to be causing the issues is OS AddressBase (Internal).
