Text wrapping in reference table not available
1725
08-02-2022 01:19 PM
AliciaShyu
I'm using Insights in ArcGIS Online (v2022) and I can't format columns in a reference table. As you can see the column formatting option is not available.
Is there a setting I need to turn on?
Alicia
2 Solutions
Scott_Aulen
@AliciaShyu,
If you select one of the fields first, you should be given the option to format.
Scott
Scott_Aulen
@AliciaShyu,
This is a bug we're working to fix. Developer has identified it and proposed a fix so this should be addressed in an upcoming release.
Scott_Aulen
@AliciaShyu,
Scott
AliciaShyu
Thanks for the quick reply. I noticed the wrap text does not include the header. Is there an option somewhere else to wrap the header text?
Thanks!
Scott_Aulen
@AliciaShyu,
Ian_Muehlenhaus
I do not believe so, but I may be wrong. Others may correct me. This is a potential feature enhancement.
Thanks for bringing this to the Dev Team's attention and thank you for using ArcGIS Insights!
Ian
Ian Muehlenhaus
Location Analytics
