Manual Classification Chloropleth Map
1469
05-06-2022 01:02 PM
Ed_
by MVP Regular Contributor
Hello,
Let's say I have a variable:
variable = 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
How can I define a custom classification in Insights Desktop as following?
5-6
7-8
9-10
Question | Analyze | Visualize
KateMaclachlan
Ah yes, so the trick to that is to change the number of classes before you switch the classification type to manual.
So if you switch back to say natural breaks, then adjust the Number of classes, then switch to manual, you will have the right number of classes. This is something we have identified in our backlog to improve.
Hope this works for now!
Kate
KateMaclachlan
Hi Saadullah,
So in your screen shot above you're almost there! after switching to manual classification you should be able to click on the blue class separators and a text box should come up in which you can adjust the variables.
Hopefully this helps!
Kate
Ed_
Cheers @KateMaclachlan , but how can I add more blue ticks (classes) while performing a manual classification?
KateMaclachlan
Kate
