Label columns in a column chart
1242
08-07-2025 06:52 AM
LeonKincy
Hello. I am using ArcGIS Insights for ArcGIS Online. I have a column chart that male and female columns. Is it possible to label the columns with both F and M and the numbers?
Tags (1)
AkshayHarshe
I think you have a 2 categorical fields on the bar chart. I only works when on Bar, column and line charts with one category. E.g Gender/ sum of population. If you have a unique value renderer on the bar chart then try and remove that.
Akshay Harshe
CodyPatterson
MVP Regular Contributor
Hey @LeonKincy
https://doc.arcgis.com/en/insights/latest/create/bar-chart.htm
In this post here, near the very bottom could you possibly use the Edit Labels button to create custom labels with this information?
Cody
LeonKincy
Hi, @CodyPatterson. I need for the labels to staticly appear on the chart not just when I hover. Also I am using a column chart.
AkshayHarshe
@LeonKincy Labels are available on Single category Bar, column, and line charts.
Akshay Harshe
LeonKincy
This looks like what I want, but when I click on layer options, I can access appearance, but not symbology.
AkshayHarshe
Akshay Harshe
