Is Insights for ArcGIS customizable with 'R', Python, or something similar?
1018
12-13-2017 01:34 PM
MatthewKohberger
New Contributor III
I'm in the process of evaluating ESRI's Insights for ArcGIS application against Microsoft's Power BI application.  Users can customize Power BI using R to expand its statistical analysis capabilities.  Can users customize Insights for ArcGIS using 'R', Python, or something similar?  If yes, how?
Thanks!
Matt
DouglasCochran
Occasional Contributor II
Yes, It is possible to have a function in the database (SQL Server, Oracle, SAP Hana, etc.) that runs an R script and result can be consumed just like any table view in Insights – the script will be run when adding it and can be run anytime by using the update in Insights.  Currently, there is no UI to run scripts from directly from the Insights UI.  This is in our future plans.
Hope that helps.
DouglasCochran
Hope that helps.
MatthewKohberger
New Contributor III
That helps. Thank-you!
Matt
PeterGoedbloed
New Contributor III
Thanks Douglas, does this only count for the Enterprise version? Of does it also work in the Online version.
