Filter by Financial Year
1569
01-28-2020 05:30 PM
BushtelAdmin
G'day Again
I need to supply a rolling count of number of visits to locations over the financial year, 1 July to 30 June.
At the moment I have a Year Predefined Filter and a Month Predefined Filter.
So last month I had 2019 checked in one window and Jul - December in the other window.
This month things go wrong as I need to check 2019 and 2020 but don't want to see 2019 Jan results.
I'm assuming the way forward is to create custom filters.
I would also like the end users to keep the ability to chose the historical year(s) and month(s) they may be interested in.
Thanks for your ideas!
Tags (1)
Scott_atEsri
Hello Bushtel,
Yes, data can be filtered at the dataset level or the card level.
Filter data—Insights Create | Documentation
We also have a predefined filter designed for viewers to interact with, however that does not currently support temporal data.  This is a good enhancement request that we have heard.
Add a predefined filter—Insights share | Documentation
If you change your date field to a string field, that may give you some more options for interactivity, and using cross filters to filter correctly.
Scott_atEsri
Hello Bushtel,
BushtelAdmin
G'day Scott
Thanks for that. I needed an interactive card for view only end users.
I ended up making a custom filter expression with date related sql.
