Can I summarize data from multiple datasets?
1268
01-27-2020 06:03 AM
AsafEvenPaz
Our organization has several partners and some of them collect data in several feature layers. I would like to analyze the data from a single partner which has several datasets or from multiple partners which each have a single dataset but do not see any such option. Would I need to store this data in a single dataset table or can I summarize data from the different datasets in a single workbook?
ArthurHaddad
Esri Alum
Thank you for this question an apologies for team not answering sooner.  In ArcGIS Insights, you can use each dataset to generate summaries or use the "create relationships" feature to join them into one table within Insights.  Not sure how you would like to summarize the data (map, chart or table) but this can be done in Insights.
ArthurHaddad
Esri Alum
