Dynamic Default Extent in Map Card
157
4 weeks ago
Status: Open
JulieCarraway
New Contributor II
I would like to be able to set a zoom extent in a map card, and have it remain at that extent when I change a filter that is tied to the data set.  The current default zoom level doesn't allow for much context for a geographical location of a single point.
Currently, I can change, and then lock the extent for one selection, but then it just stays on that location of the map if I change my filter.
1 Comment
AkshayHarshe
Hi @JulieCarraway
I do understand this functionality of setting the max zoom level isn't available in ArcGIS Insights. We support all the Zoom levels (LODs) available on the basemap. This is why zooming in to a point location can cause it to zoom in farther than expected.
Insights does honor the layer visibility range set on the feature layers. Alternatively you can also choose to turn on the lables.
Thanks for submitting this idea
