Add ability to rotate labels in Charts
925
06-15-2023 07:42 AM
Status: Open
PPoudel
I was working on an Insights report when I noticed that labels on the column charts only auto-rotate if more than 5 columns are present. Therefore, if your column names are long and if you have 5 columns or less, the labels overlap.
However, if you have more than 5 columns, the labels auto rotate and shorten, making the charts look much cleaner
It would be great if we had more control over the chart labels to make sure that they look clean and work with our data
2 Comments
Ian_Muehlenhaus
Hi @PPoudel,
Thanks for this recommendation. We'll add it to our internal idea discussions.
Sorry the labels are so cluttered for you. 😞
Thank you for using the Esri Community to share your idea and comment. Our goal is always to make ArcGIS Insights as useful as possible for our users like you!
Best,
Ian
ChrisWesson
This should have nothing to do with the number of columns. The change should happen automatically when the text does not fit.
If this is still an issue in latest release and you can kindly provide us with an example, we can investigate this as a bug.
