ArcGIS Indoors: Generate Indoor Pathways creates empty output
1309
10-11-2020 06:22 AM
RashmiTagore
Hi All,
I am trying to generate indoor network and when i run the "Generate Indoor Pathways" tool with all the required layers/inputs (Level, Details, Unit features) the output featureclass generated is empty. The tool runs without any error.
Has anyone else faced this issue and can guide me on this?
Thank you!
by Anonymous User
Not applicable
Hi Rashmi,
Please contact customer support and they can help identify the problem.
RahafDomitDaher
hi
I have an issue with creating the pathways with pro 2.8, I run generate pathways for 4 floor building and the result pathways appear all in the same Hight (on the ground ) . even I run the same tool with same data in pro 2.5 and it was working. do you have an idea why ?
SteveBowley
Hi, were you able to get a solution? I'm having the exact same problem with empty preliminary pathways, thanks!
