ArcGIS Enterprise 11.1 Indoor Viewer Application not working
1303
05-21-2023 10:26 AM
Suleyman-Arslan
Recently we upgrade Ent 11 to 11.1 and as a result our Indoor viewer application is not working on chrome browser. But it is working on Edge.
I do not know if it is a bug.
Chrome Version 113.0.5672.127 (Official Build) (64-bit)
It is looking for "floorFilterUtils.js" and get 404 error as seen on chrome console below.
moment.js:287 Deprecation warning: moment().subtract(period, number) is deprecated. Please use moment().subtract(number, period). See for more info.
O @ moment.js:287
(index):150 [esri.core.watchUtils] 🛑 DEPRECATED - Module: esri/core/watchUtils
🛠️ Replacement: esri/core/reactiveUtils
:gear:Version: 4.24
n._consoleWriter @ (index):150
EsriLib.ts:305 esriNS.version 4.25
Speech.js:72 Speech::_initVoice voices Array(27)
Views.tsx:554 No webmap was specified
value @ Views.tsx:554
/portal/jsapi/jsapi4/esri/views/support/floorFilterUtils.js:1 Failed to load resource: the server responded with a status of 404 ()
index.html:1 Refused to execute script from 'https://domain.com/portal/jsapi/jsapi4/esri/views/support/floorFilterUtils.js ' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
(index):30 Error: scriptError: https://domain.com/portal/jsapi/jsapi4/esri/views/support/floorFilterUtils.js
at t ((index):6:37)
at HTMLScriptElement.<anonymous> ((index):29:339)
(anonymous) @ (index):30
Suleyman.
Tags (3)
GauravJobanputra
Hello @Suleyman-Arslan this is not expected. Please provide some more info:
  • Is this only happening in Chrome from any machine or just one particular machine?
  • What happens in Incognito mode?
  • Have you tried to clear cache or reinstall the browser?
  • How did you perform the upgrade process?
Your responses will help troubleshoot further.
GauravJobanputra
Suleyman-Arslan
Hello @GauravJobanputra ,
Sorry for false alarm.
I was tested with incognito window, and also get same feedback from the users.
Clearing cache solve the problem.
Thanks.
GauravJobanputra
Good to know. Happy to help.
