Space Planner - Filter Reorder Option
1595
03-13-2025 11:51 AM
Status: Open
MollyE
It would be very beneficial to be able to rearrange the order of the filter options within the Space Planner app. It seems it is organized alphabetically currently and with the filter options we regularly use, it makes the order of choosing the options very unintuitive.
For example, we have have the filter enabled for the fields "Site Name", "Parent Department", and "Department" and would ideally be displayed in that order but they are currently displayed with Department first, then Parent Department then Site Name. I would like to have a couple more optional filters in there but it currently just adds confusion/clutter for the user since I cannot just put the optional ones at the bottom.
Just a thought!
5 Comments
GauravJobanputra
Hello @MollyE, is it possible for you to check and confirm it the filter order matches the order of the fields in the attribute table in ArcGIS Pro? You can rearrange the fields and see if the order in the filter gets updated.
MollyE
@GauravJobanputra I have looked at the order they are in both in pro and the AGOL and the order there does not seem to matter. It is just alphabetical within the space planner.
Andrew-Bowne
Same issue here.  I have tried to reorder my fields to display as "Organization", "Department", "Title" however it is not reflected in the filter.  As mentioned by @MollyE , it appears to be alphabetical.
MollyE
My work around for this was adding leading numbers to the field aliases. Not ideal because they also appear in the filter but it is the best solution I've come up with.
Andrew-Bowne
Interesting discovery and great workaround.  It looks like the sort is numeric but not alpha.
