Serving Orthorectified Mosaic Imagery
3212
05-02-2012 07:17 AM
DylanConrad
I am trying to serve NITF imagery and have it Orthorectified on the fly using a mosaic dataset of DT2 DEM files. I have successfully created an orthorectified mosaic dataset with NITF (WV1) images. But, once I publish my mosaic data to ArcGIS Server, the resulting service is no longer orthorectified! What am i missing!? Any help would be greatly appreciated.
Dylan
JeffreySwain
When you are adding the NITF rasters are you specifying the DTMs in the properties of the Raster Type?  Or applying the geometric function?
DylanConrad
Thanks for the responce.  I orthrorectify by specifying the DEM in the raster type property.  I found the solution for my problem.  My DEM files are located on a different server and i did not use UNC paths to connect to this data.  the images were orthorectified fine until published to a service.  to fix the problem i created a connection to the other server using the UNC path name.  Problem Solved!
