Is there way to disable MXD containing image services for publishing as GIS service?
2406
06-11-2013 08:56 PM
larryzhang1
Dear Team,
Is there any easy way to configure image services at ArcGIS image server 10.1 (saying, ???A???), in order for us to disable any customers/programmers directly publishing MXD at other regular ArcGIS Servers, if this MXD contains image services from ???A????
The idea is that the image server ???A??? will allow all desktop users and web applications to consume / directly load image services from ???A???; but wouldn???t let them directly publish MXD as map service, when containing any existing image services from image server 'A' or ESRI.
Thanks for assistance in advance.
larry
In fact, it looks that same rule is alreay applied to 3D server (globe services), which disables any 3DD re-publishing intention, if including any globe services from 'A' or ESRI.
larryzhang1
Just for update,
On clarification (�??Basemap layer�?? and �??Map services�??) from Alexey, it is clear.
The ArcGIS Server layers in MXD are not supported in ArcGIS Server for republishing as map service (OK in the drawing engine used to cache the basemap layer locally within ArcMap.)
Please link to http://forums.arcgis.com/threads/86487-Is-there-way-to-disable-MXD-containing-image-services-for-pub...  for details.
Thanks
