image server 10 add server dialog box not showing up
3052
10-24-2010 09:31 AM
brianrathburn
Recently installed arcgis image server 10 and when I open the image server manager and attempt to add a server the dialog box will not come up, anyone know what might be causing this?
briandr
MelanieHarlow
If you're using a newer OS, such as Windows Server 2008 you may need to right-click on the Server Manager in the Programs list and choose to Open or run it as an Administrator.
brianrathburn
Thanks that did the trick
Brian
