Function Thumbnails not appearing in Image Service
1405
10-30-2017 12:05 AM
SimonJackson
When I create thumbnails for my raster function templates and reference them from a folder that is accesible to the GIS Server, I still dont see them preview when I view them in the Map Viewer.
Is there a best practise for getting thumbnails to flow through to the Map Viewer interface?
SimonJackson
Bumping.  Let me know if you need more info.
EarlMedina
If you're seeing this behavior with ArcGIS Server 10.6 then this will be: BUG-000111485: The raster function templates for image services do not load in the ArcGIS Online map viewer.
The issue is caused by the { } characters in the exportImage request which corresponds to the Thumbnail shown when navigating to the Image Display rendering properties in the Map Viewer - HTML encoding fails and { } are not properly translated to %7b and %7d, respectively.
An example of a properly translated exportImage request:
https://gisserver.test.com/server/rest/services/testRaster/ImageServer/exportImage?bbox=-90.00000000...renderingRule=%7b%22rasterFunction%22%3A%22Classified%22%7d
