Exporting Blank Image When using Rest Services on Image Server
3617
09-28-2010 02:53 PM
GregoryDillon
If I browse to the url http://someserver/ArcGIS/rest/services/WUAGISAerial  and then:
1) Choose the "Export Map" (under supported operations) option
2) Select "Image" under "Format:"
3) Click "Export Map Image"
I should see the image data, but instead I get a blank image (if I click the Preview tab in ArcCatalog for this same service the image data displays).
I even looked in the C:\arcgisserver\arcgisoutput folder and found the png image it created and its definitely blank.
Is exporting blocked in Image Server or is there something special I need to do.    I'm running 9.3.1.
GregoryDillon
Strangely enough this seems to resolved itself.    I seemed to be having a problem with the rest service being cached.    Is there a way to clear the cache.    For example,   I just changed the layers in an MXD converted to a MSD pointed a service to it, yet it still seems to see the old service layers.
WenxueJu
Gregory,
REST cache can be cleared through "http://someserver/ArcGIS/rest/admin" or restarting IIS. There could be a browser side cache as well so you may start a new browser session.
Regards,
Wenxue
