Derived Mosaic Datasets
4572
06-17-2011 04:57 AM
AndrewEnglar
Documentation here: http://help.arcgis.com/EN/ArcGISDesktop/10.0/Help/index.html#//009t000001vr000000.htm
States: "By using the Table raster type you will create a mosaic dataset containing all or a selection of the table items in the source mosaic datasets."
Question: How is a selection of data added? I'm not seeing where to add a query of the data before adding it.
I'm have a master mosaic, and need to create sub mosaic datasets that can be used for displaying the different product types individually that are contained in the master. I know that a reference can be used, but I need to be able to create and maintain overviews for these sub mosaic datasets as well, which referenced mosaics cannot do.
Andrew Englar
MeganBirch
Were you ever able to resolve this issue?  I'm looking to do something similar and not really finding too much information.
JeffreySwain
What the help document is discussing is that when you use the 'table' option you will see the entries for the individual rasters and overviews in the Mosaic Dataset.  Since you can see the individual rasters in the new mosaic dataset copy, those individual rasters can be removed, queried or had functions added to them individually.  When you select the option to simply add the mosaic dataset directly as a raster dataset, then you will only see the reference to the original mosaic dataset.
To make a second mosaic dataset containing only a selection from the first, there are two options:
Using a Selection:
1. Add the first mosaic dataset to ArcMap.
2. Using the selection tool, select the footprints of the items you want to add the second mosaic dataset. Such as using the Select Features By Rectangle tool or opening the attribute table and making a selection in the table.
3. Open the Add Rasters To Mosaic Dataset tool.
4. Select the Table raster type.
5. Drag the mosaic dataset layer to the Source text box on the tool
6. Make any other relevant changes and run the tool.
Use a Query:
1. Open the Add Rasters To Mosaic Dataset tool.
2. Select the Table raster type.
3. Expand the Advanced Options.
4. In the File Filter parameter enter an SQL query. For example, if you want to ingest everything that has an ObjectID less that 5 type: OBJECTID < 5
5. Make any other relevant changes and run the tool.
