Train Deep Learning Model with multiple GPUs in Single Machine
2405
6
11-14-2023 07:08 AM
JadedEarth
I'm using ArcGIS Pro and Deep Learning API version 3.2.
I was told that this version now supports training deep learning models using a single machine with multiple GPUs.  I have such a machine configured.  I selected in the Environment panel GPU as processor type and left the GPU ID as blank since there are multiple GPUs.
Is this how to instruct ArcGIS Pro Deep Learning to use multiple GPUs?  My model type is HED Edge Detector (Pixel Classification).  Does anyone know if HED is supported for multiple GPUs?  I have tried all possible model types and only HED came close to identifying field boundaries for my project.
Appreciate any response.
PavanYadav
Hello @JadedEarth
By default, the tool uses all available GPUs when the Model Type parameter is set to one of the following
  1. ConnectNet
  2. Feature classifier
  3. MaskRCNN
  4. Multi Task Road Extractor
  5. Single Shot Detector
  6. U-Net
These are the only supported model types currently for multiple gpus. Also, the deep learning tools only support CUDA capable GPUs.
regards,
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
JadedEarth
That's unfortunate.  I need Holistically-Nested Edge Detection (HED) model for my particular project.  I've tried all the models you mentioned and none of them provided results like HED.  I was hoping ESRI will support this model.
PavanYadav
@JadedEarth
I have shared your feedback with the team.
thanks
Pavan
Pavan Yadav
AI for Imagery
PriyankaTuteja
Dear @JadedEarth
The multi-gpu support for deep learning models listed here is available.
Please note: The multi-gpu training is supported with command line only. If you are trying to use ArcGIS Pro tools, it would not work.
JadedEarth
Can you show me the link to instructions on how to run multi-gpu from command line?  There should have been instructions/guide to do this from the outset.  When you advertised that multi-gpu is supported, nowhere did it state that it only works for command line and there are no links to instructions on how to go about it.
PriyankaTuteja
