Solution for Change Detection for Large Area
3631
09-08-2024 08:44 AM
Muhmmad_Ali
Hi , I appreciate your valuable inputs in the below challenges
Challenge no.1: performing Change Detection CD Process utilizing two different time series satellite high resolution satellite imagery for large area (more than 150,000 Sq.Km ). Currently CD has been performing manually – where group of analysts visualize the two satellite imageries then digitize the changes – and I work to automate the CD process, my approach is to use Esri pre-trained deep learning models for object classes as Building, Road & developing new models for 9 more classes then run the 10 models on the two imageries to detect the objects then I identify  the changes , I have two questions: -
  • Is the above-mentioned approach, correct?
  • Most of Esri pre-trained models’ precision ranges from 64% to 92% & I tried to enhance them by doing transfer learning methods, but always ending up with lower precision percentage, is it impossible to target more than 95% precision score?
  • What is the best geospatial method to identify changes from the detected objects throughout the process?
  • Is there any better approach to perform CD process automatically & in efficient way?
Challenge no.2: I am trying train a model that detects the below objects, is it possible to train one model able to detect the below objects efficiently?
PavanYadav
@Muhmmad_Ali thank you for posting here.. I believe a problem can have multiple solutions and the solution you are considering looks good to me. But, sharing some other  approaches below for your consideration.
Answer to "Challenge no 2" -- yea.. because I can detect it with my naked eye.. as long as enough training data you can train a model to detect that (and, similar objects) . Quality of models depends on the training data.. and some other techniques.. I am sharing two my blogs on effectively creating and using training data for object detection: Tips for labeling images for object detection models (esri.com) and Tips for training data preparation for object detection models (esri.com)
1. Binary change detection (change or no change) -
workflow do: https://pro.arcgis.com/en/pro-app/latest/help/analysis/image-analyst/detect-change.htm.
notebook: https://developers.arcgis.com/python/samples/change-detection-of-buildings-from-satellite-imagery/
2. Multi-class change detection using image segmentation deep learning models
https://developers.arcgis.com/python/samples/multi-class-change-detection-using-segmentation-deep-le...
3. Less common
1. Do object detection using the same Deep learning model against before and after rasters.. next, use intersect (or, other similar) tool to understand the change.
Additional resources:
https://pro.arcgis.com/en/pro-app/latest/help/analysis/image-analyst/change-detection-in-arcgis-pro....
https://pro.arcgis.com/en/pro-app/latest/help/analysis/image-analyst/time-series-change-detection.ht...
https://doc.arcgis.com/en/imagery/workflows/resources/image-change-detection.htm
Hope this helps.
Cheers!
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
PavanYadav
3. Less common
Hope this helps.
Cheers!
Pavan Yadav
AI for Imagery
Muhmmad_Ali
Many Thanks Pavan , Your usual support & feedback is always appreciated.
