Fine-Tune deep learning detect objects - swimming pool
1477
02-26-2025 05:47 AM
Letíciad_Agosto_Miguel_Fonseca
Hello everyone,
I’m currently working on fine-tuning the pool detection model for use in southern Brazil. I followed the steps outlined in this post: https://doc.arcgis.com/en/pretrained-models/latest/imagery/finetuning-the-pool-detection-usa.htm
Raster information:
Training Samples:
Parameters:
Image training sample (0.3m):
However, the results I'm getting seem a bit unusual:
Does anyone have any suggestions on how I can improve these results?
Thanks in advance!
PavanYadav
Hi @Letíciad_Agosto_Miguel_Fonseca it does look concerning. The model is trained with 8-bit, 3-band high resolution (5-30 centimeters) imagery. What kind of imagery did you use to create the training samples. Can you share a screen capture of its stats.txt file?.it should look something like this example
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
Hello @PavanYadav , first of all, thank you for your attention. Indeed, I noticed some inconsistencies.
Here is the stats.txt from my training samples:
The .TIFF image I exported from the .ECW file is showing 4 bands, although there are only 3.
I re-exported it using the Raster to Other Format geoprocessing tool and now it is right:
Now, the statistics for my training samples (62 swimming pools) are as follows:
However, I believe I need more training data and better resources to fine-tune the model. When I tried running the tool, my ArcGIS Pro crashed, and it's not feasible to use 100 epochs and a batch size of 64.
I’ll try running it on another server and see if I can successfully fine-tune the model.
If you have any more suggestions on how to improve, please let me know.
PavanYadav
@Letíciad_Agosto_Miguel_FonsecaSorry for the late response. ArcGIS Pro shouldn't crash even if the batch size exceeds GPU memory. Can you try using a smaller batch size, such as 2 or 4? More training samples should also help. Another thing to try is building a new model solely with your training data (don't use the pre-trained model as a starting point) to see if you get any meaningful results.
Cheers!
Pavan Yadav
AI for Imagery
