Detect Object Using Deep Learning. Error 'No module named torchvision.models.detection.retinanet'
4550
02-03-2023 10:05 AM
MattiaScalas
I'm trying to use the TreeDetection deep learning model with some raster imagery (ArcGIS Pro 2.8).
I get an error 002667 Cannot load python module when I add TreeDetection.dlpk as Model Definition in the geoprocessing Detect Object Using Deep Learning. The error is:
ModuleNotFoundError: No module named 'torchvision.models.detection.retinanet'
How can I solve this problem? Is it a problem linked to my ArcGIS version?
DanPatterson
MVP Esteemed Contributor
were you following
Train Deep Learning Model (Image Analyst)—ArcGIS Pro | Documentation
for your version of Pro?
... sort of retired...
PavanYadav
@MattiaScalas Have you installed the Deep Learning Packages? if not, please download and install them (see link below) and retry.
https://github.com/Esri/deep-learning-frameworks
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
ShariF
Hi.
I was having the same issue. I was working in a cloned environment under Package Manger and kept getting errors. I realized when I read the fine print of installing the deep learning frameworks, that the installation from github is updating the non-cloned environment. I had always read to NOT touch the arcgispro-py3 environment or there would be dire consequences. I do not get errors now. Good luck and I hope you have success with the Tree Detection. I'm trying out the Tree Segmentation for the first time.
https://www.linkedin.com/in/shariforbes/
