Compute Accuracy For Pixel Classification ArcGIS Pro 3.5.1
1422
07-08-2025 09:57 AM
Ed_
by MVP Regular Contributor
Hello ESRI, so this new tool in ArcGIS Pro 3.5 is pretty neat, however I have a couple of questions. I have noticed that the tool returns different accuracy results each time the tool is ran even though the input data (pixel classification raster and ground truth feature class) along with the number of random points stay the same. For example in two instances I got accuracies of 47% and 52%.
Is this because of the random distribution of points? like the spatial distribution of the random points is different each time the tool is ran?
Which of the above two accuracies are correct then 47% or 52%?
Question | Analyze | Visualize
PavanYadav
@Ed_
just wanted to add, there are 3 different modes to create the AA points. please consider the equalized stratified random mode which puts the same number of AA points per class. Then the overall accuracy has each class contribute equally.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
DanPatterson
MVP Esteemed Contributor
Compute Accuracy For Pixel Classification (Image Analyst)—ArcGIS Pro | Documentation
neither is correct per se, except for the instance that it applies to.
experiment with the sampling strategies as well as the number of points
... sort of retired...
PavanYadav
@Ed_ Yes, it appears to be because of the default 5000 random distribution of points. I feel we should increase the default from 5000 to a larger number.
Pavan Yadav
AI for Imagery
PavanYadav
@Ed_
Pavan Yadav
AI for Imagery
