Block adjustment error
2238
04-02-2021 12:24 AM
Daniel1
Hi All,
I have a question. I am working on one project. I'm using ArcGIS Pro and I'm stuck on one step. Looking for the cause of the problem, I came across post here https://community.esri.com/t5/imagery-and-remote-sensing/block-adjustment-error-with-gcp-s/td-p/5602... How to solve this?
DanPatterson
MVP Esteemed Contributor
The other question wasn't resolved.
There are 5 known and posted bugs associated with "block adjustment"
Did you review them to see if your situation is common?
Esri Support Search-Results
... sort of retired...
Daniel1
The only possible thing is that my operating system is not English. What can I do to make it work for me?
CodyBenkelman
Daniel
we'll need a lot more information to be able to help you - details like:
  • which version of Pro?
  • which data type - drone? scanned historical film? satellite?
  • how many images?
  • do you have adequate overlap along each flightline, and between multiple flightlines?
  • did the tools succeed in finding tie points between images?  (first step in the "adjust" tool)
  • What did the process log say?
I'd suggest you open a support ticket at http://support.esri.com/ so an analyst can help.  Also note we've published a lot of resources about workflows and best practices for Ortho Mapping (and many other topics) at https://www.esriurl.com/imageryworkflows e.g. https://doc.arcgis.com/en/imagery/workflows/resources/creating-drone-imagery-products-with-ortho-map...
Cody B.
Daniel1
This is ArcGIS Pro 2.5. The data type is a drone. About 50 images. I have adequate overlap along each flightline and between multiple flightlines. Tools succeed in finding tie points between images.
The process log is identified as listed here https://community.esri.com/t5/imagery-and-remote-sensing/block-adjustment-error-with-gcp-s/td-p/5602...
