Survey123 displays incorrectly when opened within ESRI Hub
1089
08-08-2023 01:01 PM
ScoutStanley
I am having issue where any surveys I have added within our Hub site open with incorrect display/format. We have 4 surveys which are used within a gallery card. Each one of them opens up in same tab.
Incorrect Format Below
Correct Format Below
Anybody know how to fix or if this is a bug?
David_McRitchie
I would recommend raising this as a Technical Support case as it sounds like it might be a bug where appearance options are being overwritten by the ArcGIS Hub site.
If you change the appearance options of the Gallery card does the Survey appearance also change?
Many thanks,
David
Esri UK -Technical Support Analyst
