osm
4487
6
06-16-2016 12:41 AM
tinigjeo
hi can you tell me the right street, if i use osm (open street map ) it's not problem if i add point,ect and finally with done one map on scale that i want
2.But resulation of map lose?
AlexanderWinz
What exactly is your question?
tinigjeo
how can import point ddmmss on osm?
can i make new map on pdf with point ddmmss from pdf ?
AlexanderWinz
If you like to zoom in OSM to an certain point (coordinate) you can use:
http://www.openstreetmap.org/?mlat=latitude&mlon=longitude&zoom=12
You can also enter latitude,longitude in the search box.
tinigjeo
thanks but another problem is the name of the city can i  cut out from osm
AlexanderWinz
I am not sure, but I think I will not be possible, because the annotations (labels/names) are not rendered dynamically. They are parts of the tiles (basemap).
In this case you have to create your own map in ArcGIS and exclude certain labels/names.
tinigjeo
thanks for your answer
