OpenCycleMap in ArcMap Desktop
4772
09-12-2014 01:37 PM
AviSchwartz
Hi all,
I am really new to ArcMap Desktop and GIS in general so please excuse my ignorance.
It looks like that from File: Add Data: Add BaseMap, you can't add OpenCycleMap which contains Contour Lines and SRTM only OpenStreetMap.
SRTM - OpenStreetMap Wiki has a link to converted contour lines calculated from SRTM data to OSM  Index of /SRTM/srtm_as_osm
which I want to overlay on the OpenStreetMap BaseMap to create the equivalent of the OpenCycleMap.
Is this the right way of doing it?
I downloaded the relevant OSM files but I am having trouble loading it in ArcMap.
In Catalog: OpenStreetMapsToolbox:  I clicked "Load OSM File" but I don't know how to set the "Target Feature Dataset".
Where is the .gdb file located? Do I need to set up a "Database Connection"??
Many thanks!!
DanPatterson_Retired
without checking them myself did you check out the links to OpenCycleMap by querying this site?
AviSchwartz
