Open Data Search for Applications
3745
08-04-2015 05:10 PM
BradySmith
I am trying to set up our open data site and cannot figure out how to get an application to show in a search. From the documentation it appears it should display and launch from the search window since it is using the url, or am I mistaken?
This excerpt below is from the help documentation .
The following data types are supported in ArcGIS Open Data but do not have their own dataset page. Users can search for these items within a site and access them directly from the search results page. These items will not appear on opendata.arcgis.com:
  • Web maps—The web map will open in an ArcGIS Online Map Viewer in a new tab
  • URLs—The registered URL will open in a new tab
  • Documents—Word documents will download in the browser
  • PDFs—The PDF will open in a new tab
CourtneyClaessens
Hi Brady,
We don't support web applications directly at this time - that is, ArcGIS Online items that are web applications will not appear in the search. However, if you copy the web application link and create a new ArcGIS Online item that is a document link, it will appear in the search results and the user will be directed from there. It's a workaround for now until we support web apps.
In Online:
Add item --> from the web --> type: document.
Hope that helps,
Courtney
CourtneyClaessens
Hi Brady,
In Online:
Hope that helps,
Courtney
BradySmith
That worked. Thanks for the work around.
