Open Data gallery https redirect
1098
05-11-2018 09:27 AM
AdamMesser1
Trying to troubleshoot an http vs https problem on our Open Data page. We have shared a test site for troubleshooting. There is a page gallery for Hunting Applications with a web map application link to the Hunt Planner application hosted on our agency page. The problem is the link from the Open Data page redirects to an https url. On our Open Data site configuration the "Enforce HTTPS" option is set to "Off". If you search for the Hunt Planner item, the link works correctly. Our primary AGOL site has a security configuration of "Allow access to the organization through HTTPS only". Could this be impacting the Open Data site? What do we need to do to get these map application links to correctly point to an http address from Open Data?
AdamMesser1
From ESRI support: A HTTP dataset or an application when accessed through gallery, it enforces to pass the request over HTTPS.  This behavior is found to be a case defect within the application and is logged as a bug. Following are the details of the bug:
BUG ID: BUG-000109990
Synopsis: In Open data, the Gallery Guard enforces the applications or datasets to open over HTTPS even when the applications or datasets are over HTTP.
Status: In Product Plan
