Open Data basemap
1798
09-02-2024 05:07 AM
HanliePetoors
I'm working in ArcGIS Online, building an Open Data portal.
Is it possible to use a custom web map as the basemap when looking at a feature layer? I would like to give the data some context. For example, when looking at well data I would like to include exploration blocks as part of the basemap.
Thanks
Hanlie
ZiqingYu
Hi @HanliePetoors ,
are you going to build an Online App? In Experience Builder you can import a web map as basemap easily. Otherwise I think you'll need to build a tile layer first.
Best,
Ziqing
HanliePetoors
@ZiqingYu I'm building an Open Data portal as an ArcGIS Hub site. I'm not working in Experience Builder.
ZiqingYu
Well, Eventhough Experiencebuilder is still an option, using <iframe> label in HTML you can insert this app into your hub page (Actually you don't need html, just choose iframe layout from hub)
or you can export the map as a wms layer or a raster file, which can be used as basemap in map viewer.
HanliePetoors
I think you're misunderstanding my question.  I'm talking about the basemap in this interface:
It displays one feature layer at a time but it would be useful if I could put other contextual layers on the basemap.
acarmody
Agree with @HanliePetoors
You can only select one basemap in arcgis hubs settings - is there a way to add additional basemaps?
And it would be great to then get a basemap toggle button added to the 'explore' page tool bar.
Is it possible to enable that?
