Map viewer reading wrong extent parameters...
345
07-19-2022 10:21 AM
MiltonSolano
I have this orthophoto published on our hub site:
https://stridata-si.opendata.arcgis.com/maps/sherman-20cm-may-18th-2021-orthophoto
When you open the map viewer, the viewer opens to the full extent and is not reading the defined extent on the published layer. If you open the same layer on the new map viewer, the extents works just fine, like in here:
https://si.maps.arcgis.com/home/item.html?id=a5d74219bf834ac6b3e0a39cd6963ce9
How can I fix this issue when opening the images? my users get lost not knowing where the image is located.
Thanks!
Milton
