Hub menu not showing
1607
10-17-2024 01:27 PM
lmarun
Hello. I have a hub site that is not showing either the name nor the menu items, but is showing the logo.
In the Header panel, I have both a long and short name filled out (and both are green/showing).
In the Menu section, I have all of the hub pages listed, and they are all published.
I've tried toggling between Standard and Prominent, and Box and Wide, etc. to see if I could nudge something, but no luck.
Any thoughts?
Thanks!
AndrewTurner
Hi @lmarun - sorry to hear that you're having a problem. My initial thought is there there is a Style setting which has the same color text as the background color. The next would be some custom CSS that is hiding or changing the header.
If you can share the site URL then that would help us provide more specific guidance.
AndrewTurner
lmarun
Hi, Andrew.
You're brilliant! The header text was set to white! Thank you so much!!!
