Hub Basic Invalid client_ID error at sign in
1450
05-03-2021 10:43 AM
AndreaKrzystan1
I'm working on my first Hub Basic site and have run into an 'Invalid client_id' error (see attached) when attempting to login to the Hub site directly via the site address. The Hub site is shared to a group within an organization and does not have a custom domain. I can access the site when navigating to it from the group contents page or if I am already signed into a group member named user account and then open the Hub site address in a new browser tab, but not if I navigate to the site address without already being signed in to AGOL.
After creating the site, I ran into the "Cannot save domain changes" error when I updated the site name in the default URL, but was able to fix that following the solution from this post: Cannot save domain changes solution
Before finding that solution, I had unregistered the Hub site as a troubleshooting attempt, but have since re-registered it. Following some additional research, I see that the Hub site App ID is not included in the sign in pop-up URL (https://www.arcgis.com/sharing/oauth2/authorize?response_type=token&redirect_uri= https...). The missing App ID in that URL seems to be causing the Invalid client_id error since I can manually add the App ID to the sign-in pop-up URL (https://www.arcgis.com/sharing/oauth2/authorize?client_id={AppID}&response_type...) and the Sign In screen works as expected.
Is there a way to re-link the new App ID with the site to fix this sign in error?
ArmstKP
@AndreaKrzystan1 We are running into this exact same issue.  Were you able to get it fixed?
