Getting a 404 Error Creating Events
1518
09-11-2020 12:38 PM
DevinLavigne
I am getting a 404 error when I try to create an event on my initiative. I'm not sure if something got messed up with the data file but I haven't found a way to repair it or reset it.
by Anonymous User
Not applicable
Are you able to clone the site and use the clone instead once it is setup with the same content (note - custom domains can transfer instantly because you already have an HTTPS certificate on the current site)? If not, I can probably repair it manually but will need to be invited to your organization. This is something we should clean up automatically...apologies that we don't.
by Anonymous User
Not applicable
Is it public - can you send us a URL?
DevinLavigne
It is. I'm investigating this further and it looks like there is a Hub application but not a Hub Initiative.
Forward SGF is the custom domain
This will also get you there.  Thanks Graham.
https://springfield-comp-plan-hlplanning.opendata.arcgis.com
by Anonymous User
Not applicable
DevinLavigne
Okay. Seems to have worked. We will "flip" the custom domain switch once we are comfortable everything is there.
