Cards inside same gallery open inside AND outside of hub....
988
01-31-2023 03:03 PM
ArmstKP
I am using ArcGIS Hub.  In a gallery, I can click on one card and it will open the webapp outside of hub.  In the same gallery, I can click on another card and it will open the webmap inside of hub.  Why aren't all of the cards in a gallery acting the same?
Here are my Interaction settings:
anbinh
It sounds like whether HTML has "target='_blank'" attribute. If you know HTML well, the "target" attribute specifies where to open the linked document. It can control whether open it in a new tab or inside the tab.
I assume you did not change any HTML code, but it worths checking if it accidentally has any target attribute attached, or if you were using different types of gallery cards.
Providing more screenshots may help. Still hope this helps though.
Cheers,
Anbin
ArmstKP
@anbinh I have 16+ cards in my gallery.  How do I check the html for each card?  Or is there one setting for all the cards?
