ArcGIS Hub supporting https on custom domains
14006
35
06-08-2018 06:50 AM
DarrenHaag
A Question on ArcGIS Hub / Open Data.
Is there a timeframe for supporting https on custom domains?  If not, is there currently a workaround that can be applied (requesting a new ssl, etc..) to ensure https traffic has no issue accessing the custom domain?
Tags (4)
by Anonymous User
Not applicable
We have issued HTTPS certificates for all the existing custom domains that we could. We ran into a few that had issues with how their domain issuing authority set up their domain that we're working through.
Later this year we'll be adding support for enforcement on your custom domains.
Please test out your domain over HTTPS and let me know if you have problems!
Edit: also all new custom domains registered to a Hub Site should get their HTTPS certificate within 24 hours
by Anonymous User
Not applicable
I am still getting a not secure error:
by Anonymous User
Not applicable
it appears your CNAME was not setup to exactly to our documentation. You need to set your CNAME according to the below instructions exactly: Rather than setting the CNAME to your site's URL you set it to the hub.arcgis.com URL so our infrastructure can let your CNAME move from site to site.
Given a few others have had the same issue we're going to make a few updates to the UI that sets this in the coming months.
by Anonymous User
Not applicable
Yep you are correct, we had to do that originally because it wasn't working the way you describe before. I swapped it over this morning through and the new CNAME is working without issue. Thank you
by Anonymous User
Not applicable
I can now go to https://maps.grey.ca and that works fine. However when I type in just maps.grey.ca into a url bar it defaults to the unsecured version. Are there are redirects on your end to ensure it's going to the https version?
by Anonymous User
Not applicable
We're planning on enhancing the URL configuration (and validation) process for custom domains in the next few months. As part of that, we'll be allowing users to enable Enforce HTTPS for their custom domains once we have the validation that the cert process was successful.
DarrenHaag
The site worked when visiting through https.
Thank You and the team for their hard work on this!
Quick question, we will be doing a major push on our open data initiative and I am about halfway done building the site.  When we push this live, it will also have a custom domain.  Are any new sites automatically getting a cert or should we work with esri to make sure it happens?
by Anonymous User
Not applicable
We should issue a cert within 24 hours of your domain being registered to your Hub Site.
NathanEnge
Graham
Is the approx time still about 24 hrs to get a cert issued for custom domains?
https://office.esripacific.ca
cheers
nathan
by Anonymous User
Not applicable
that's our under promise over deliver guarantee!
*is not an actual guarantee, there are a lot of external factors at play for certificate generation. :tm:
we usually turn them around much quicker than that
